prerender times in vegas 6
Posted by Niklas on September 11, 2005 at 6:58 pmIs it possible for a one hour project in vegas 6 to have a message of 15 hours of render time for the prerender files before printing to tape…
Almost impossible…
Rob Mack replied 21 years ago 3 Members · 5 Replies -
Rob Mack
September 11, 2005 at 7:05 pmTotally possible. All sorts of things can cause that, even accidental bumps of your track opacity could be adding to it.
Rob Mack
Rob Mack
September 11, 2005 at 7:07 pmIf this is 15 hours to prerender for ptt, maybe you should make sure you just render the thing and save the rendered file. You can even cut things into the rendered file later on rather than making a change and having to render everything again.
Rob Mack
Niklas
September 11, 2005 at 8:51 pmYeah but even with the rendered file… won’t it prerender it again for ptt?
thx
Edward Troxel
September 11, 2005 at 9:09 pmIf you put a DV-AVI file on the timeline and then PTT, it will NOT have to do any more “prerendering”.
15 hours for a 1 hour video IS possible. Typically, mine take much less than that. Without knowing anything about the project (and possibly seeing the VEG file) there’s really no way to tell if 15 hours is “appropriate” for your project.
Rob Mack
September 12, 2005 at 5:09 amEven if you render to sony yuv your next render to ptt won’t take that long. The only reason the current ones taking 15 hours is that there’s some serious processing to do. If you do it once to a fairly good format, like YUV or uncompressed then you won’t have to go through all of that again.
Rob Mack
