Activity Forums Apple Final Cut Pro Legacy Prepping shots for export for VFX work and not losing highlights above 100
  • Prepping shots for export for VFX work and not losing highlights above 100
    Posted by Alexandre Brandt on September 22, 2014 at 4:13 pm
    Hello all,
    I have Apple Pro Res 422 footage in my timeline (FCP 7), footage that was shot C300. I’m editing online with the ProRes 422
    Some shots will be worked on in some other programs for some compositing etc.
    I’m going to export those shots but before I do so I want to make sure that I bring the overexposed areas from 110 percent white to at 100 white so that I don’t lose the details in the highlights in the workflow.
    My questions is, in FCP what is the best way to do that ? Should I use the 3 way color corrector and bring down the highlights while looking at the RGB Parade video scope ?
    Thank you !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Producer | Filmmaker
    http://www.alexandrebrandt.com
    Alexandre Brandt replied 11 years, 11 months ago 3 Members · 4 Replies
  • Shane Ross
    September 22, 2014 at 4:31 pm
    [Alexandre Brandt] “Should I use the 3 way color corrector and bring down the highlights while looking at the RGB Parade video scope ?”
    Yup. nailed it
    Shane
    Little Frog Post
  • Michael Cheung
    September 22, 2014 at 4:34 pm
    As a VFX editor I’d test these things with your VFX vendor. It’ll probably save a lot of time if something was wrong.
    Michael Cheung
    https://filmcutter.blogspot.com
  • Alexandre Brandt
    September 22, 2014 at 6:46 pm
    Ok. Thanks Shane.
    -> FILMMAKING !
  • Alexandre Brandt
    September 22, 2014 at 6:47 pm
    Yeah we could do a workflow test one 1 shot, thats not a bad idea.
    Thanks.
    -> FILMMAKING !
