Activity Forums Apple Final Cut Pro Legacy Prepping for TV
  • Prepping for TV
    Posted by Rj Miles on September 15, 2007 at 3:47 pm
    Can anyone point me to links to read up on prepping for digital delivery to a TV station?
    For instance:
    the best codec for delivery (mpeg2 @ 18-25MB/s or ?)
    DVD -vs- downloading from an FTP server (:15/:30 spots)
    bars/leaders-slates/black timing at the head & tail of the spot
    waveform adjustments for setup and proper legal color control
    anything else I am overlooking. 🙂
    We usually send out spots on Beta SP. However, this current project will go to 75 stations and we are looking for some ways to save some cabbage without screwing the pooch.
    We have looked at a company specializing in taking our spots and hosting them on a server, and pushing them out to the stations (which might need to be on the network?). However, they end up being more $$$ than the SP delivery path.
    I did check Ken Stone’s site to see if he covered the topic. Maybe the topic is easily viewed somewhere else?
    Thanks for any link or comments you can offer.
    Walter Biscardi replied 19 years ago 4 Members · 5 Replies
  • Rj Miles
    September 15, 2007 at 3:50 pm
    How about audio levels for the color bars versus what’s in the program?
  • Adam Taylor
    September 15, 2007 at 4:01 pm
    working in the UK, i use a service called Adstream. I send a single advert to them (either on digibeta or via upload to ftp. They then send it on to every station you request at a set fee for each item sent.
    The service i get is fantastic – they are quick and helpful and are so much more cost effective than sending tapes. We used to get charged
  • Walter Biscardi
    September 15, 2007 at 4:23 pm
    What are the specs of the stations? That’s your first step right there. You can’t deliver anything less than what the stations expect from you.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Devin Crane
    September 16, 2007 at 2:36 am
    Usually it’s 30sec of bars at -20db tone with your audio peaking no higher than -10db. 10sec of slate, 10 sec of black, countdown then your program. Some stations still require the setup at 7.5 even though they are excepting it digitally. That’s why as Walter stated you need to check with the station, don’t feel stupid asking them, they are usually pretty helpful and greatful that someone actually asked.
  • Walter Biscardi
    September 16, 2007 at 10:09 am
    [Devin Crane] “Usually it’s 30sec of bars at -20db tone with your audio peaking no higher than -10db. 10sec of slate, 10 sec of black, countdown then your program”
    Yep, as one example:
    One Network I deliver to is 1 minute of black, 30 seconds of bars, 20 seconds of slate, ten seconds of black, then project start. Audio peak no higher than -4db digital.
    Another network is 2 minutes of black, 40 seconds of bars, 10 seconds of black, 10 second slate all the way down to 1. Audio levels must not peak higher than -18db.
    Two very different specs and if I were to simply deliver one spec to the other network, it would be rejected.
