Activity › Forums › Adobe Premiere Pro › Preparing TVC to broadcast specs
  • Preparing TVC to broadcast specs
    Posted by Lucky Phil on February 2, 2015 at 5:23 am
    I am hoping for some help in preparing a TVC for broadcast. I have become used to sending out square pixel progressive material and now a bit lost with these specs!
    Basically I have a finished 1080p TVC and would really appreciate some step by step instructions for getting it to below specs in Premiere Pro CC (or After Effects if easier), the audio part I can do.
    Thanks in advance to anyone who can help, thought I’d seen the last of non-square pixels / fields etc years ago 🙂 At least they don’t want it on DigiBeta I guess…
    ProRes422 (HQ) (mov)
    Video:PAL 50i upper/top
    Apple ProRes 4:2:2 Colour
    ITU-R BT.601 or 709
    Frame size 720×576 25fps
    Display Aspect Ratio 4:3
    1.33:1 100% of source
    1.067 non-square pixel
    Audio
    PCM Audio at 48kHz
    16 bit-24 LKFS Stereo (L,R)
    Stephen Bakopanos replied 11 years, 5 months ago 2 Members · 1 Reply
  • Stephen Bakopanos
    April 7, 2015 at 2:15 pm
    Delivering to DubSat/MediaPro I take it?
    I’ve had all sorts of issues getting 1080p TVCs out of Premiere and delivered to spec.
    I even work in the same building as DubSat and have chatted first hand with the tech guys there and haven’t had a proper solution. In the end, I just submitted files in HD and let them work the magic.
    Will investigate further as I have some more TVCs coming up…
