Activity Forums Adobe Premiere Pro Preparing to switch – Avid to Adobe
  • Preparing to switch – Avid to Adobe
    Posted by Jon Doughtie on November 19, 2013 at 5:00 pm
    We are getting ready to make the switch – we’ll be leaving Avid Media Composer and coming over to Adobe CC.
    I have attached an image of a typical promo timeline we use in the Avid. The layout is:
    V2 – L3 ribbon keys and FS backtags
    V1 – promo video
    A1 – promo audio
    A3 – announcer backtag
    We re-use the timelines and just overwrite drop-in the correct episodics, use a keystroke (T) to select IN-OUT on V1 (the highlighted track) one at a time, and export each individual promo to a folder to send on to the MC server at the appropriate time. I would like to maintain this basic workflow in Premiere.
    Obviously we’ll be investigating the keyboard shortcuts for Premiere. Are some of these tasks (like selecting IN-OUT on a track) already present in the Premiere keyboard lexicon, or will we need to create a few shortcuts?
    We will be able to export each segment to queue in Media Encoder, then batch render, correct?
    Anything you might have to share to help us with a smooth transition is appreciated!
    Mike Cohen replied 12 years, 8 months ago 3 Members · 3 Replies
  • Paul Neumann
    November 19, 2013 at 7:06 pm
    PPro handles that workflow just great. Here’s what I do: Down arrow to move playhead to clip, D to select clip, / to set in and out around clip, Command + M to export panel, apply preset and add to queue in Media Encoder. Repeat. Except for the preset and destination which remain set from the previous so you only have to do that once.
  • Jon Doughtie
    November 19, 2013 at 7:25 pm
    Excellent. I figured it would be a simple process. Thank you very much!
  • Mike Cohen
    November 22, 2013 at 10:23 pm
    to replace the video in a clip on V1 for the next batch of shows, set your in and out (or actually just the in as long as the out is past the duration of the clip on the sequence) then hold ALT and drag the video from the source window to the clip on the sequence, and it overwrites the old video, maintaining the in and out on the timeline and any effects.
    Mike Cohen
