Activity › Forums › Maxon Cinema 4D › “Preparing” Takes too long when rendering?
  • “Preparing” Takes too long when rendering?
    Posted by Massimo Teresi on April 24, 2016 at 5:32 am
    So, I’m still fairly new to C4d, and for some reason, whenever I try to render a frame, it says “Preparing” at the bottom left corner before rendering. It says this for 50 seconds before it actually starts to render the frame. This is getting really annoying, because it only takes me 12 seconds to render a single frame, but the “Preparing” adds 50 seconds to each frame, thus multiplying my total render time 6 fold. This is completely ridiculous, It is not an issue with the Lightroom I am using either, my friend who has a slower computer than I do does not have this issue. He uses the same Lightroom and same exact render settings, and it does not say “Preparing” for him. It just starts rendering straight away. I know it has something to do with Global Illumination, and he and I both have it enabled, because with it off, this does not happen. Btw I am Using Irradiance Cache (Legacy) because Regular Irradiance and Monte Carlo take way too long. Do I have some settings wrong? Please help ;-;
    Screenshots of render settings:
    https://gyazo.com/e8b2710761ea6e3d93008d8e988cf616
    https://gyazo.com/979abc96e68b0e0c0b4004404824e377
    https://gyazo.com/d08653982ffb3ed65bd19195df8a0704
    https://gyazo.com/14238e849c39c44bc600b44754618911
    Kouraib Abdmalek replied 1 month, 2 weeks ago 4 Members · 5 Replies
  • Brian Jones
    April 25, 2016 at 5:39 pm
    anything else that wold be preparing in your scene (Dynamics, Particles etc)?
  • Massimo Teresi
    April 26, 2016 at 1:10 am
    Nope :/ My friend can render my same exact project, I sent him all the files, and on his machine, it completely skips the “preparing” and starts rendering straight away. He uses the same settings as me, except he uses regular irradiance cache, and I use legacy because it’s a lot faster. The render quality looks exactly the same, and on top of that, he is using an old Mac, which has a dual core Intel processor, and integrated graphics, while I’m using an i5 4670K quad core and a Gtx 970 Graphics card. It’s clearly an issue with c4d, because I can render anything else faster than him, and it’s definitely something to do with global illumination, because if I turn it off, it begins rendering straight away. Stuck :/
  • Brian Jones
    April 26, 2016 at 1:15 am
    don’t know myself never heard of that. Might be interesting to see the scene file to see what would happen here. Maybe send it to support, they’ll let you know if there is something known.
  • Pavel Levin
    August 13, 2026 at 6:56 pm
    I have the same problem. Preparing is running already 3 Minutes and there no sign of render. I need to render only last part of the sequence, the first one was rendered as usually, with out of any issues.
  • Kouraib Abdmalek
    August 14, 2026 at 9:44 am
    Hi Pavel,
    I believe this is due to one or more of the materials being used. If you’re using materials like grass or hair, and their properties are set high, calculating their effect on the scene happens during the preparation phase, which takes time before rendering even begins. This happened to me once — I spent a lot of time digging through render settings and other options until I discovered that one of the materials had a very high value in the displacement channel, using a texture with intricate detail that was being applied repeatedly across a large area of the scene’s background. Once I adjusted this, everything went back to normal. I hope this helps.
