Activity Forums Adobe After Effects Preparing footage for PAL 16:9 Footage
  • Preparing footage for PAL 16:9 Footage
    Posted by Brad Goosen on June 4, 2005 at 3:30 am
    Hi
    I am preparing some animations in After Effects for an anamorphic 16:9 Pal project in Final Cut Pro HD. I’m preparing some Photoshop files for animation in After Effects. What is the best settings for the Photoshop files and then the After Effects comp and render. I will be rendering them out to the Quicktime animation codec.
    Thanks in advance
    Brad
    John Dickinson replied 21 years, 3 months ago 2 Members · 3 Replies
  • John Dickinson
    June 4, 2005 at 7:42 am
    You can create your AE comp at D1/DV PAL Widescreen and use PAR button (or a 16×9 monitor) while working. Or you can create your comp at 1024 x 576 square pixels (no need for the PAR button) then drag that comp into D1/DV PAL Widescreen comp for the final render. You can also work at 720 x576 D1/DV PAL Widescreen in Photoshop (this is a feature included from Version 7) and use the PAR setting but I prefer to use 1024 x 576 square pixels when working in Photoshop.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Brad Goosen
    June 6, 2005 at 12:23 am
    thanks john
    that works perfectly. thanks for the prompt response… on a weekend too!
    great work on your show reel too… cool to see high quality work coming out of oz!
    thanks again
    brad
  • John Dickinson
    June 7, 2005 at 6:18 am
    Any time! 🙂
    John Dickinson
    Motionworks
