Activity Forums Adobe Premiere Pro Preparing audio for a DCP
  • Preparing audio for a DCP
    Posted by Pier-philippe Chevigny on November 5, 2014 at 2:12 pm
    Hi guys,
    I’m currently preparing to export a DCP for a 30-sec commercial to be played in theatres. It’s my first time delivering material to a theatre and I’m a bit confused by their requirements. I’m (hopefully) doing all the audio work in Premiere CC 2014 but I could switch to ProTools if need be.
    Here are the specs:
    7) The audio .wav file
    Digital Reference Level must be at –20dBFS.
    8) FOR COMMERCIAL PRESENTATION ONLY – Audio levels must not exceed a loudness level of 82dB leq. This is an average loudness over the length of the spot.
    Does that mean I should put a limiter at -20db on the master and turn down the track volumes to give a little headroom? I’m confused by the 82 db leq loudness level. Please, any help would be greatly appreciated! Thanks!
    Pier-philippe Chevigny replied 11 years, 10 months ago 3 Members · 3 Replies
  • Chris Borjis
    November 5, 2014 at 5:35 pm
    I was confused by that as well, so much so that my client actually paid for a .pdf
    file from DCI to get specifics…well there weren’t any to explain it better haha.
    So we just mixed the audio at Standard TV levels, that of hovering between -18 and -10
    with occasional peaks at -6.
    and don’t forget to export the audio as 24-bit.
    good luck!
  • Angelo Lorenzo
    November 6, 2014 at 7:05 am
    [Pier-Philippe Chevigny]
    Digital Reference Level must be at –20dBFS.”
    Digital reference is usually “dial norm” or average level. Use audio effects > special > loudness radar to measure this to approximately -20. This USUALLY DOES NOT MEAN SLAP ON A LIMITER AT -20db. A reference level is to compare dbFS (digital, 0db max) to analog levels like dbu; -20dBFS = 0dBU in this instance. In other words, 20db in headroom between average level and digital maximum.
    [Pier-Philippe Chevigny] “8) FOR COMMERCIAL PRESENTATION ONLY – Audio levels must not exceed a loudness level of 82dB leq. This is an average loudness over the length of the spot.”
    “82dB leq” is meaningless in this context. This might be a loudness reading in the theater, but you have no context as to what digital dBFS level translates to this volume. Ask for clarification.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Pier-philippe Chevigny
    November 7, 2014 at 12:58 pm
    Thank you so much guys, this clears things up!
