Activity › Forums › Adobe Premiere Pro › Prepare 24p HD video for VHS
Posted by Ken Klipps on November 21, 2014 at 7:50 amI need to get a 24fps (23.976) HD video in Premiere and my client is asking for the video on VHS. What is the best way to go about prepping the video to transfer to VHS. I plan on burning it to DVD and then recording from the DVD onto a VCR.
I’ve attempted to use Twixtor to increase the frame rate to 29.97 but the frame blending is ruining some of the quick cuts by adding single frame fades between them. Is using Twixtor overkill? Is there an easier way to prep the video for VHS so I don’t get any choppiness. This is for a music video so it eventually has to come back from VHS into Premiere and line up with the song.
Thank you.
Dustin Parsons replied 11 years, 9 months ago 4 Members · 12 Replies -
Walter Soyka
November 21, 2014 at 12:29 pmYour DVD player adds 3:2 pulldown [link], converting 23.976 to 29.97 on the fly, for standard-definition output. You don’t need to Twixtor, you can just record the output of the DVD player.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Jeff Pulera
November 21, 2014 at 4:30 pmI would first test if you can successfully copy from the DVD player to the VHS deck. Haven’t tried that myself, however I’ve had a lot of customers complain that their video capture cards will not accept analog video output from a DVD player, says “Copy Protected Material” even when using a DVD-R they made themselves. So I don’t know if a VHS recorder has any issue with recording from DVD, but something to check.
Please note that there are software plug-ins that simulate various degrees of video damage. A web search for “VHS look plugins” quickly came back with GenArts and CreationEffects for instance, check them out.
Jeff Pulera
Safe Harbor Computers -
Ken Klipps
November 21, 2014 at 5:57 pmI have successfully recorded a VHS from a DVD several times. I’m not concerned about that working. I’m mostly concerned about getting choppiness or having a difficult time syncing back up after the video is run through VHS. I don’t really want to use a plug-in because they always look fake and don’t quite have the same effect as real VHS tape.
Jeff Pulera
November 21, 2014 at 6:20 pmWell then, I think Walter nailed it – just create a 23.976 DVD and that should work. Couldn’t take more than 15 minutes to burn a short sample DVD, copy to VHS, and recapture into NLE to test sync timing.
Of course, there is the pulldown removal if you want to edit the VHS then as 24p.
Jeff Pulera
Ken Klipps
November 21, 2014 at 6:52 pmOkay sounds good. I did a pulldown in AE which gave me pretty good results. There are repeated frames as expected but I’m not sure they’ll matter or are visible to anyone who hasn’t been staring at this project for weeks.
How would I go about recapturing to NLE and doing a pulldown removal in Premiere or AE? Thanks for helping!
Jeff Pulera
November 21, 2014 at 7:13 pmHi Ken,
I was assuming you already had some method of getting the VHS footage back into the NLE…
You’ll need a video capture device with analog input, such as a BlackMagic Intensity, Matrox MXO2 Mini, etc.
Or if you have 1394 Firewire on your computer, a Grass Valley ADVC-55 will convert an analog source into DV video for capture over Firewire.
Using a BlackMagic or Matrox device will offer better quality options, such as 4:2:2 color and even uncompressed video.
Just had another thought – if you have one of those VHS/DVD combo recorder units, copy the VHS back to DVD then edit the .vob in Adobe. Of course, that is going to add more compression again. Something to try perhaps though.
Many methods to consider. The downside to any of these is going back and forth between 23.976p and 29.97i of course, as you noticed some issues already.
Jeff Pulera
Ken Klipps
November 21, 2014 at 7:27 pmJeff,
I actually have access to a Blackmagic Ultrastudio 4k. Would this work? My SVHS deck has BNC output. I’m not an experienced editor so I only know NLE as the file format my colorist wants me to send him along with the ProRes. I will want to get the file back into Premiere.
We were hoping to use the Blackmagic to bring the the VHS footage back to digital. Would we then want to remove the pulldown back to 24fps?
Ken Klipps
November 21, 2014 at 7:30 pmoops, im confusing EDL and NLE. EIther way, would the Blackmagic Ultrastudio 4k work?
Jeff Pulera
November 21, 2014 at 7:40 pmAs long as the capture card accepts analog composite, good to go. However, I have no experience with 24p workflows/conversion myself.
Jeff Pulera
Ken Klipps
November 21, 2014 at 9:22 pmJeff, thanks so much for all your help. I have one last question if you don’t mind:
I have the final video exported as a 1440×1080 4:3 .mov using the H.264 codec (I have two versions – one in its native 23.976 and one “pulled down” version in 29.97 lower fields first interlaced that I got from using the pulldown in AE)
I now need to resize the video and compress it to burn onto a DVD using Apple Compressor. I found some tutorials online but even following those steps, the compressed video comes out very bad looking and all the text is blocky and pixilated. Is there a better way to compress to SD for DVD that will keep the video looking good? I know on commercial DVDs the quality is good for what it is even though its brought down from, say 35mm to standard def.
Also, should I use the 23.976 version or the 29.97 version when burning to the DVD? Basically, would it be better to use the pulled down version or let the DVD player do its own pulldown before the video heads to S-VHS?
Thanks again.
