Activity Forums Compression Techniques Prep An Hour-Long Video for the WEB?!
  • Prep An Hour-Long Video for the WEB?!
    Posted by Lillian Young on May 28, 2010 at 3:19 am
    How can I compress this huge video down to a few MB for the web?
    SOURCE
    Apple Animation
    770×578
    22.05 MHz
    30 FPS
    44.84 GB
    106.48 Data Rate
    1 hr. 17 Duration
    GOAL
    No specs were provided, just a request to get the file size down from its current 594MB. I was told to use the Screen video 2 codec, but I’ve never heard of that and don’t have it.
    ABOUT
    This video is a business webcast screen capture with some small text in charts that needs to remain crisp.
    SUGGESTIONS?
    I have no idea what to do because a small h.264 with low/med. settings rendered an 8-9 MB file from 2 minutes of footage, so I doubt I can get this hour-long footage “small.”
    Any suggestions would be appreciated.
    Craig Seeman replied 15 years, 11 months ago 2 Members · 1 Reply
  • Craig Seeman
    May 28, 2010 at 3:48 am
    [Lillian Young] “Apple Animation
    770×578
    22.05 MHz
    30 FPS
    44.84 GB
    106.48 Data Rate
    1 hr. 17 Duration
    Sorry but you need to have them send you the specs. Most of these make absolutely NO sense.
    22.05 might be KHz
    44.84 GB makes no sense given you say
    [Lillian Young] “down from its current 594MB”
    106.48 data rate. Huh?
    Get the right information from them please.
    [Lillian Young] “I was told to use the Screen video 2 codec, “
    Window Media Encoder has it. It’s efficient for screen captures. I hope they have a good reason to eliminate all the Mac OS users in the world because that codec can’t be played on the Mac OS.
    [Lillian Young] “I have no idea what to do because a small h.264 with low/med. settings rendered an 8-9 MB file from 2 minutes of footage, so I doubt I can get this hour-long footage “small.” “
    H.264 has nothing to do with the size. The data rate you choose does. You’ll have to do a bit of math to figure out data rate for the given duration to the targeted file size.
    [Lillian Young] “just a request to get the file size down from its current 594MB”
    Here’s a math question for you. 77 minutes is 4620 seconds. 594MB divided by 8 would make it 4752mbits. What is the data rate in kbits/second?
