Activity Forums Adobe After Effects Prep AI layers for AE (complex artwork, but only certain layers need animating)
  • Walter Soyka
    December 11, 2020 at 9:38 am
    I would do the prep work in Illustrator, where it’s a lot easier to see what you’re doing.
    When you import .AI files into Ae, you have the option of importing as a composition. Each layer in Illustrator will be a layer in After Effects, and if there are multiple shapes in the same layer in Ai, they’ll be smushed together into a single layer in Ae.
    To get everything you need on its own layer in Ai, you use “Release to Layers (Sequence)” and then re-arrange a little bit:
    https://www.shutterstock.com/blog/importing-illustrator-files-into-after-effects
    If you’re going to be doing a lot of Ai-to-Ae work, you might appreciate Overlord:
    https://www.battleaxe.co/overlord
  • Andy Di Leo
    December 24, 2020 at 4:17 pm
    Thanks so much!
