Activity › Forums › Adobe After Effects › Premultiply – matted with color
Posted by Graham Macfarlane on September 2, 2011 at 5:25 pmI have a layer with transparency which needs premultiplying with black but I would rather not render it out in order to apply the standard interpret footage method as it will create a massive intermediate render.
Is there a way to achieve this same premultiplying effect on a single layer (using AE CS5)?Many thanks
GrahamGraham Macfarlane
3D animator and VFX specialist
London UKWalter Soyka replied 15 years ago 4 Members · 7 Replies -
Tudor “ted” jelescu
September 2, 2011 at 7:13 pmThis tutorial may give you the answer you are looking for:
https://library.creativecow.net/rollason_ben/lens-flare/1Tudor “Ted” Jelescu
Senior VFX Artist -
Darby Edelen
September 2, 2011 at 7:14 pmCould you explain a little more about what it is you have and what you’re doing with it? I’m having a hard time figuring out why you’d need to premultiply footage for a workflow within AE.
Are we talking about removing premultiplication?
Darby Edelen
Walter Soyka
September 2, 2011 at 7:31 pmChannel Combiner has a straight-to-premultiplied option.
Solid Composite will let you stick a black matte behind your transparent layer.
But, like Darby, I’m curious as to why you want pre-multiplication in AE.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Graham Macfarlane
September 5, 2011 at 1:29 pmTudor, thanks for the link. Very useful info there!
Darby and Walter,
I have an asset containing coloured blurry graphics against black (no alpha channel) which I wanted to be against white. When Track Matting the asset in AE to make an alpha and using this over a white background one sees dark fringing in the blurry edges of the graphics.I could have rendered out the asset with this alpha and then loaded it back in and interpreted the footage using, Premultiplied – Matted with colour (black) but I wanted to avoid the extra file space usage of an intermediate asset.
The Channel combiner effect does exactly what I need!
Many thanks for your help guys!Graham Macfarlane
London UK -
Walter Soyka
September 5, 2011 at 1:37 pmYou can also use Red Giant Software’s free UnMult [link] next time you need to remove a black background from a semitransparent object.
Walter Soyka
Graham Macfarlane
September 5, 2011 at 1:41 pmDownloading now!!!
Cheers!Graham Macfarlane
London UK -
Walter Soyka
September 5, 2011 at 1:48 pmHappy to help!
I was a little thrown by your original question, because AE doesn’t really expose premultiplication to the user like many other compositors do, but it all makes sense now.
Walter Soyka
