Activity Forums Adobe Premiere Pro Premire Pro CS4 exporting error
  • Premire Pro CS4 exporting error
    Posted by Damir Spanic on April 12, 2010 at 12:39 am
    While exporting short project with Adobe Media Encoder It say: – Source File: C:\DOCUME~1\IMAGEM~1\LOCALS~1\Temp\Fight_01_1.prproj
    – Output File: L:\Photo\March 2010\Dijan\Bob Sapp\Movies\Sequence 01.avi
    – Preset Used: PAL DV
    – Video:
    – Audio:
    – Bitrate:
    – Encoding Time: 02:11:02
    4/1/2010 12:35:23 AM : Encoding Failed
    Could not read from the source. Please check if it has moved or been deleted.
    Also I have never saved any file in that Temporary folder.
    And as 2nd when I try manually to ad Sequence to exporting Queue it say Adobe dynamic link error occurred. It is short project fully rendered. 1 min 36 second long. Please help. It is my fist project ever. I do stills just wanted to go motion. Help! Thank you.
    http://www.maximum-image.com
    Marley Paranhos replied 16 years, 3 months ago 2 Members · 2 Replies
  • Damir Spanic
    April 12, 2010 at 1:50 am
    Sorry I found answer in forums by Phillip Verdoni:
    CS4 Premier installed on your computer. You can probably get out of this issue doing as follows:
    Create a shortcut to the Premiere Pro executable file, rename the shortcut to Premiere, and move the shortcut to C:\Program Files\Common Files\Adobe\dynamiclink (If you installed Premiere Pro CS4 in a location other than the default of C:\Program Files\Adobe, then navigate to your custom installation location.).
    1. Close all Adobe applications.
    2. In Windows Explorer, navigate to X:\Program Files\Adobe\Adobe Premiere Pro CS4.
    3. Right-click on Adobe Premiere Pro.exe (which might appear without the .exe extension) and choose Create Shortcut.
    4. Rename the newly created shortcut to just Premiere.
    Important: The name of the shortcut must be exactly Premiere with no other characters- sans extension.
    5. Open a second Windows Explorer window, and navigate to C:\Program Files\Common Files\Adobe\dynamiclink.
    6. Move the Premiere shortcut that you created into the dynamiclink folder.
  • Marley Paranhos
    June 2, 2010 at 4:08 pm
    I am com the same problem, Already moved the project to another HD, Has eliminated the project and created a new and yet, Keep getting this error message when exporting, Saying that "can not read the source file, Check has been moved or deleted ".
    This occurs in Premiere CS4.
    Could someone help me?
    Grateful.
