Activity Forums Adobe Premiere Pro Premiere’s Unseen Keyframes
  • Premiere’s Unseen Keyframes
    Posted by Andrew Diesel on June 17, 2015 at 8:01 am
    Hi there Guys
    A program that I truly adore along with the adobe links with areas that I’m still learning about.
    The one that I can’t see past and is rather annoying is when you add and remove keyframes in your clip’s transformation settings (Motion, Opacity, Time Remapping) but there is still evidence of the removed keyframes in-between two cloned keyframes.
    If someone could please explain this and how best to restore, I’d be really appreciate it.
    Andrew Diesel
    Andrew Diesel replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
