Activity › Forums › Adobe Premiere Pro › PremierePro/EncoreCS5 Frame Swapping
  • PremierePro/EncoreCS5 Frame Swapping
    Posted by Dan Fedida on July 21, 2010 at 12:11 pm
    I’m having the strangest problem with Premiere Pro CS5:
    I’m editing shows ranging from about 1hr 30 to 2hrs 30 in PP CS5 and using dynamic link to author in Encore CS5.
    Only by complaint have I noticed that at a random point in the video, either PP or Encore has swapped two frames around from different points in the video.
    It is only apparent after the transcode so I deleted it and re-transcoded. The EXACT same frames were swapped!
    I can’t explain it! Has anyone else had this glitch?
    Jon Geddes replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jon Geddes
    July 22, 2010 at 6:56 pm
    I’ve experienced many glitches with the dynamic link feature. When it works, it is nice, but often times it does not. If you encounter a glitch like this, you will need to transcode before bringing into Encore.
    Jon Geddes
    http://www.precomposed.com
