Activity › Forums › Adobe Premiere Pro › PremierePro CS3/Cuts out audio in source window
Posted by Charles Westfall on July 1, 2009 at 10:39 pmWhen I capture a clip and save it to the project window, if I click that clip to playback in the source window and the “conforming” progress bar at the lower right hand corner of the screen hasn’t finished conforming the clip, it cuts out audio on the clip that is playing back in the source window. It will play audio on any portion of the clip that has been conformed, but not on any portion that hasn’t been conformed. Anybody know of a way to stop that from happening?
Ben Forder replied 17 years, 1 month ago 4 Members · 11 Replies -
Vince Becquiot
July 2, 2009 at 1:01 amBasically, wait until the conforming is done? That process creates the audio preview files, without it, no audio…
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Charles Westfall
July 2, 2009 at 1:29 amThat is what I do now, but it doesn’t help me when a director is angry because he can’t hear the audio when he wants it. Is there any way to prevent conformation from happening? The techs at adobe told me that if the settings are the same during capture as the settings are in the project settings, it shouldn’t have to conform the file. I am using a AJA Xena LHE card with Premiere so maybe there is no way to keep the settings the same. Basically, no one at Adobe had an answer. If I record a twenty minute clip in HD, conforming takes about five minutes. The director on the set is not going to wait for that to happen. That’s my dilemma. Thanks.
Vince Becquiot
July 2, 2009 at 2:33 amA twenty minutes clip should take just a few seconds. What format are you capturing with on the AJA card, and what are the specs on the machine?
Vince Becquiot
Kaptis Studios
Charles Westfall
July 2, 2009 at 2:45 amWe were recording a Red camera. 1280×720, AJA quicktime format, DVCPro HD to save hard drive space. I am using Windows Vista 64 bit. I was told by the tech at Adobe today that CS3 was never intended for Windows Vista. Supposedly CS4 is much faster with Vista. That may be part of the problem if not all of the problem.
Vince Becquiot
July 2, 2009 at 2:55 amThat’s possible, but I wouldn’t count on an upgrade to solve it. We ran CS3 on Vista for some time and I don’t remember experiencing longer conforming/indexing.
Quicktime DVC Pro HD could be the issue. Especially the QT part, Premiere has had a lot of issues with anything Quicktime for the past 2 years, CS4 was not help…
I know that you don’t have many options for encoding, but I would be tempted to try something else, at least a native AJA codec to start and see if that helps.
Vince Becquiot
Kaptis Studios
Terry Hahin
July 22, 2009 at 10:05 pmHello Vince,
I noticed you have been helpful in the past to people with audio playback issues so I thought I might ask you. I think I might have the same issue that maybe I cut off conforming while it was happening…thus resulting in a clip that plays back only partial audio.Don’t do that…obvious answer.
But how does one “re-conform” the audio again? It doesn’t even work if I open a brand new project, then re-import that clip. PP CS4 just seems to know the clip and refuses to let go of it’s bad conform files.
I’ve tried cleaning the media cache with no luck. Any suggestions?
Terry Hahin
Designer and Editor
terryhahin.com -
Vince Becquiot
July 22, 2009 at 10:59 pmIn Vista and CS4, things are a little different, you’ll have to go to Control Panel > Folder options > View and change the setting to show hidden files and folders.
Then go to: C:\users\{your user name}\App Data\Roaming\Adobe\Common\Media Cache Files then delete everything inside that folder. Keep in mind that this will delete ALL conformed files. See if this solves your problem.
Vince Becquiot
Kaptis Studios
Charles Westfall
July 23, 2009 at 3:48 amThanks Vince. I’ll see if it works after I get CS4. I’m still waiting for AJA to fix their NTSC bug with CS4 before I buy their capture card.
Charlie Westfall -
Charles Westfall
July 23, 2009 at 3:56 amOkay Vince, I now realize that you were responding to someone else. I will not do what you suggested when I get CS4. I know you were trying to help someone that had stopped audio conforming and needed to get it back.
Charlie Westfall
