Activity Forums Blackmagic Design PremierePro and DVCPro50
  • PremierePro and DVCPro50
    Posted by Shane Chadder on June 15, 2005 at 7:02 pm
    Does anyone know if I buy a a decklink capture card does it include drivers that would allow me to capture Pro50 via firewire?
    Can you mix codecs on the timeline eg. dv25, dv50, and uncompressed or do you can to convert everything to uncompressed?
    Sun Da qing replied 21 years, 2 months ago 3 Members · 4 Replies
  • Luke Maslen
    June 16, 2005 at 8:17 am
    Hi Shane,
    The short answer is “no.” Premiere Pro 1.5.1 will happily capture DV25 and HDV via Firewire but not DVCPRO. The DV25 or HDV captures are then transcoded to an uncompressed format which DeckLink can use. DeckLink can then play out the uncompressed video to a deck and/or monitor via SDI or analog outputs, depending upon which model of DeckLink card you have.
    In regards to mixed formats on the one timeline, they need to be uncompressed to work with DeckLink cards. We have a tech note about compressed formats with DeckLink cards at:
    https://www.blackmagic-design.com/support/detail.asp?techID=101
    It should provide some background information about using compressed formats on both Mac and Windows.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Shane Chadder
    June 16, 2005 at 4:20 pm
    Thanks Luke
    Is it the same deal with Mac? Do you have to render every file captured to the same codec as the timeline to work in realtime? So if you are working uncompressed you have to render your DV files to uncompressed?
  • Luke Maslen
    June 17, 2005 at 3:04 am
    Hi Shane,
    Yes and No. With Final Cut Pro HD v5.0 and DeckLink Macintosh v5.0 drivers, you can mix some different formats together on the same timeline. However exactly what you can mix together without rendering is dictated by the speed of your Mac. The faster Macs can mix a range of compressed codecs on the same timeline. Having said that, there is no documentation Final Cut Pro documentation which would provide an idea of what you can expect to work and therefore one simply has to experiment with a system to determine its capabilities.
    Even though a FCP5/DeckLink5 setup can playback some mixed compressed codecs on the same timeline on faster G5’s, I would highly recommend rendering all the material to one format before recording to tape. However the ability to mix formats on the same timeline can be a real timesaver when editing.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Sun Da qing
    June 23, 2005 at 9:41 am
    Now you can!
    You can capture dvcpro50,mjpeg,huffyuv in winodws.When you finished the program,You can output timeline via sdi with out render.And any format files in the timeline is realtime.like mpeg1 mpeg2 mpeg2-I wmv divx…….
