Activity Forums Adobe Premiere Pro Premiere/Prelude Quitting Problem
  • Premiere/Prelude Quitting Problem
    Posted by Alexander Freedman on October 18, 2013 at 3:06 pm
    Hello all,
    Both Premiere and Prelude will not close after I open them (all other CS6 apps close fine). Has anyone else had this problem? I only found one post on the Adobe Forums with no solution.
    “Command+Q” and “Premiere > Quit Premiere” do nothing. I also found I cannot open another Premiere project or create a new project. Premiere just sits indefinitely, no spinning rainbow wheel. Right clicking on the icon in the dock does not offer the “Force Quit” option that’s sometimes available if the application isn’t responding. So in all aspects it seems to be working absolutely fine.
    I’m able to save and continue working on the currently opened project even after I try to quit it. I simply can’t quit it, open another project, or start a new project, Premiere just stares at me. No abnormal background activity. The only way to close it is to force quit the program through task monitor or command+option+escape.
    Premiere doesn’t seem to be crashing and it saves all my project data so not a life-or-death situation but, still, very annoying as I often need to switch between projects.
    I’m on a Mac Pro OSX 10.8.5.
    Adobe Update Manager for my CS6 says everything is up-to-date. I’ve opened different projects; I’ve started new dummy projects and tried to immediately close them and still no luck.
    Any ideas would be greatly appreciated!
    Alexander Freedman replied 12 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
