Activity Forums Compression Techniques Premiere/Encoder CS5 to Vimeo HD – best settings
  • Premiere/Encoder CS5 to Vimeo HD – best settings
    Posted by Bogdan Brak on June 21, 2011 at 12:01 am
    hey guys.
    I could need some help with exporting my animation footage. Hope you’re in the mood, even if the topic sounds “disgusting” ;).
    I’ve made an animation in After Effects and rendered it out as a TIFF-sequence. From the beginning it’s 25fps/PAL/1280×720.
    In Premiere Pro CS5 I placed the footage into a sequence with 44.1 samplingrate and added the songs that is also recorded in 44.1.
    right now it looks like this: https://vimeo.com/20301514
    password: gastlog
    for this version I used the vimeo HD preset of the encoder (only changed it into PAL and 25fps.) but I’m sure that there must be a better setting. somehow I think it’s getting out of sync and sometimes it lags.
    any sugestions how to make it better?
    thanks in advance
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Bogdan Brak replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
