Activity Forums Adobe Premiere Pro Premiere won’t play updated audio track
  • Premiere won’t play updated audio track
    Posted by Mike Phares on December 10, 2015 at 11:53 pm
    Now, this is weird. I imported an audio track into Premiere CC and then noticed i needed to re-edit it. I re-opened my audio file in Audition where I do my tracking, fixed the track and re-saved it. I re-imported the track into Premiere and when I played it, it was still playing the first version. I renamed my edited track and re-imported it into Premiere, and it STILL played the first version. I finally had to do the re-edit in Premiere (which is always rough) to make it work. Any suggestions?
    Thanks.
    Mike Phares replied 10 years, 9 months ago 2 Members · 2 Replies
  • Tom Blizzard
    December 11, 2015 at 10:14 am
    Hi Mike. I’ve had that happen more than once. It seems the program has to think it out a bit. I found that if I save the project and close down the program, when I reopen the project, it works. Once I had to completely shut down my computer. Not a very technical answer, but it worked for me.
  • Mike Phares
    December 11, 2015 at 5:36 pm
    Tom, thanks so much for replying. Since I posted, I did what you did, trying anything I could think of, and lo and behold, it finally accepted the corrected track. Premiere must have a memory print or something! Best to you!
