Activity › Forums › Adobe Premiere Pro › Premiere won’t let me change frame size
Posted by Blahtor Magnus on February 3, 2009 at 10:24 pmHi guys,
please, check out the screenshot below.How do I manually set Video Frame size in Premiere CS4?
In my case, the spaces where you are supposed to put custom values are greyed-out (inactive).
I tried creating all kinds of projects with all kinds of sequences in them – no result.Harry Moreno replied 13 years, 4 months ago 8 Members · 10 Replies -
Eddie Lotter
February 3, 2009 at 11:17 pmYou have chosen an editing mode that has a specific frame size, which as you have discovered cannot be changed.
Choose the “Desktop” editing mode and you can specify the frame size you want.
Cheers
Eddie -
Adumi So
May 27, 2009 at 6:11 pmHi eddie,
The `Desktop` format allows me to set the frame size only when I create the new sequence , but after it was created I can`t change frame size settings – it`s disabled. Is it possible at all to fiddle with a sequence`s frame size AFTER it was created ?
Thanks -
Eddie Lotter
May 27, 2009 at 6:12 pmUnfortunately not, but what you can do is copy the clips on the old timeline and paste them into the new timeline. Very handy. 🙂
Cheers
Eddie -
Richard Glendenning
November 14, 2011 at 5:23 pmHi Eddie,
Where do I find the option to do Desktop Editing Mode?
Cheers,
Rich
Sumeet Dabral
December 30, 2011 at 5:07 amhiiii Eddie Lotter….
Sir will you please suggest me from where i have to select “DESKTOP EDITING” mode…..
Please help me as soon as possible…..
Warm regards
SUMEET DABRAL -
Paul Whishaw
August 24, 2012 at 11:07 pmI find this a little frustrating. Not so much for video clips but for titles. I am so used to being able to manipulate titles in FCP, duplicate, new text, duplicate new text. Now I have to create a new title for every single piece of text. Which is interesting until you are trying to upres from 720 to 1080 and you can’t actually change the size of the text “files” you’ve created.
I can increase them to 200% or whatever but come on, let me resize the original Adobe. Really.
Paul Whishaw
PDVpro.com
“If it moves, We’ll Shoot it” -
Daniel Campbell
January 29, 2013 at 9:16 pmYeah, I’m actually having a lot of trouble finding where to enable the “Desktop Editing” option as well. Any way someone could point out where this is really quick? Pretty please?
Harry Moreno
April 21, 2013 at 3:16 pmProblems finding the desktop mode?
Under Sequence Preset you make a selection you like. Under the other tab ‘General’ you can select desktop mode under ‘Editing Mode:’
Than after editing in the od size i cant export in common formats like ‘H264’. Only in FLV i cant export the video in the od proportions. Is there a solution to export od sizes in H264?
