Activity Forums Adobe Premiere Pro Premiere with Pro Tools?
  • Premiere with Pro Tools?
    Posted by Cybele on October 26, 2006 at 1:53 am
    Hello,
    I’m interested in using Pro Tools MBox2 with Premiere Pro. I’d like to be able to export video from Premiere and sync it with audio in Pro Tools. Does this work well? What do I need for my basic Pro Tools MBox 2 system to do this, like plug-ins, etc? Any suggestions would be really helpful!
    Thank you!
    Cybele
    Mark Johnnidis replied 13 years, 6 months ago 5 Members · 5 Replies
  • Blast1
    October 26, 2006 at 6:02 am
    After you get through processing the audio in protools why don’t you import it into premiere?
  • Cybele
    October 26, 2006 at 5:20 pm
    I’m wondering if I need DV Toolkit. It’s really expensive, so if I can avoid getting it, I will. I’m used to an older Pro Tools MBox system on a Mac, working with Final Cut Pro. I want to make sure I’m getting the right thing. I know that Audition is the Adobe sound program with Premiere, but I’d like to use Pro Tools, as I know it a lot better, and like it a lot better. I’m still learning all this stuff, so I need some guidance.
    Thank you!
  • Jeron Coolman
    October 26, 2006 at 7:11 pm
    cybele,
    I love ProTools and used it extensively, but I find myself using Audition with Premiere Pro instead. The integration between the two programs, if you have Dynamic Link, is far better than the import/export “dance” you will have to go through with ProTools and Premiere Pro.
    I didn’t feel like I had much of a learning curve either. If you know how to use ProTools, Audition should be fairly easy to pick up and start using. ProTools is still my favorite DAW, but I just haven’t found a reason for me to use it instead of Audition when it comes to my Premiere Pro projects.
    Jeron
  • Alex Udell
    October 27, 2006 at 11:36 am
    Hi…
    If you are looking for the traditional mix to picutre functions of Pro Tools from an editorial project you started in Premiere….
    A customer of mine has used the followng workflow:
    1) Export Premiere as AAF
    2) Open the AAF in a copy of Avid Xpress
    3) Export OMF
    4) Bring OMF into Pro tools
    That seemed to work. The Adobe AAF is not compatible with Pro Tools Directly.
    Alex
  • Mark Johnnidis
    March 19, 2013 at 12:50 pm
    Is there a workflow going the other way? I am unfamiliar with pro tools but we will be recording and mixing a live performance in pro tools and recording on 5DMK3’s and will be syncing & editing all of it in Premiere Pro CS6. Does Premiere accept OMF files? What workflow hiccups should I be anticipating?
