Activity › Forums › Apple Final Cut Pro Legacy › premiere – Wind noise on audio track
Posted by Elaine Walton on November 3, 2008 at 9:27 pmI have a lot of wind noise during an outside wedding ceremony. I use Adobe premiere and would like to know how to lower the noise while keeping up the level of audio for the JP talking.
Dennis Radeke replied 17 years, 10 months ago 5 Members · 4 Replies -
Jeremy Garchow
November 3, 2008 at 9:17 pmYou might get more responses if you post the Adobe Premiere forum:
https://forums.creativecow.net/forum/adobepremierepro
Jeremy
Ben Holmes
November 3, 2008 at 10:53 pmJeremy’s right – but good luck with the wind noise, it’s a b**** to remove. You can try a band-pass filter to try to help, but it’s pretty hard on any NLE software.
Any mic used outdoors like this should be all dressed up in a wind-shield. This is what soundmen are for (and it’s the only thing they’re for, apart from moaning).
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer -
Michael Gissing
November 3, 2008 at 11:46 pm[Ben Holmes] “This is what soundmen are for (and it’s the only thing they’re for, apart from moaning).”
Yes, us ex location soundmen have heard it all before. We are quite interchangeable with drummer jokes too.
The bottom line is that sound is always 60% or more of a final production. It rarely gets above 5% of the budget, so it is the best value for money on any production. How about taking half the grade or graphics budget and seeing what you can do with good sound.
If I said you were only there to randomly push the insert button, would that be a fair description of and editor?
Didn’t think so.
Dennis Radeke
November 4, 2008 at 2:06 pmAdobe’s Soundbooth and Audition both have tools to remove Wind Noise. Essentially, all you have to do is select a section of audio that is only wind noise, tell Sb or Au that it is noise and then remove it. I didn’t look at this tutorial, but it sounds like this would give you insight on how to do it.
https://www.wrigleyvideo.com/videotutorial/tutdes_soundbooth_noisecancel.htm
The thing for me is that both Adobe products allow you a 3 dimensional view of audio (time, frequency, amplitude) vs. a waveform view which is 2 dimenional (time, amplitude)
