Activity › Forums › Adobe Premiere Pro › Premiere will only let me play from in-point to out-point
  • Premiere will only let me play from in-point to out-point
    Posted by Anne Colton on August 23, 2017 at 12:52 pm
    I have in and out points set on my source clip, but I would like to jump earlier just to check what’s before my in-point. When I hit the space bar, the payback will only start at my in-point. The only way to play back something from earlier in the clip is to clear the edit points. Is there a way to make it play back anywhere on the clip, regardless of edit points?
    Bathinda Helper replied 2 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Ann Bens
    August 23, 2017 at 1:14 pm
    Space bar should not play in to out, Enter should.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Anne Colton
    August 23, 2017 at 1:19 pm
    Agreed. But it’s not doing that right now. Space bar is only going in to out. Another editor was working on my system, so he might have changed something, but I have no way of contacting him. Is there a way to fix it? I feel like it must just be a box that needs to be checked…
  • Anne Colton
    August 23, 2017 at 1:45 pm
    Never mind, I figured it out… on the source window, under the WRENCH icon, there’s a setting called LOOP. I unchecked it, and all is well again. Thanks!
  • Jeff Hight
    October 31, 2018 at 6:20 pm
    Even though you figured this out on your own, I thank you because this was just messing with my head why space bar kept doing in-out. Thanks again!!
  • Carolyn Lecorre
    February 8, 2019 at 8:37 pm
    Thank you! I started working at a new place and tried to remap over and over again the keyboard (it was mapped correctly in the first place). I didn’t know about that Loop option.
    Those little things cause or save lots of grief
  • Doug Brown
    November 21, 2019 at 12:30 am
    Thank you Ann. 2 years later, I just had the same mental lapse. Gotta love the COW!
  • Bathinda Helper
    June 28, 2024 at 2:37 pm
    Thank you very much. It got really tough to find answer to this problem on Google. Logged in just to thank you.
