Activity Forums Adobe Premiere Pro Premiere > Ultrastudio Digi Beta, drop-in / pickup results in 2 frames of black
  • Premiere > Ultrastudio Digi Beta, drop-in / pickup results in 2 frames of black
    Posted by Toby Risk on July 29, 2016 at 8:08 am
    Hi
    There must be a setting for this, but I’ve been through everything I can find.
    Picking up an edit-to-tape from PPro CC to Digi Beta, via a Ultrastudio HD-SD downconvert we are getting 2 frames of black at the edit point.
    We’ve advanced the timeline edit point by 2 frames to adjust for the Ultrastudio 2 frame delay on conversion. The video is placed in the correct place, ie: the offset is correct, but the Ultrastudio is not queueing PPro early enough to feed the images in time to reach the digi beta deck at the edit point, resulting in a 2 frame black hole at the edit.
    I can’t believe there isn’t an adjustment for this, but the only one I found is in Playback > Video device > offset in ms but this seems to have no effect.
    Anybody else, found / solved this one.
    Cheers
    Toby
    Toby Risk replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
