Activity Forums Adobe Premiere Pro Premiere tripping on footage captured on screen
  • Premiere tripping on footage captured on screen
    Posted by Joel Thiessen on October 15, 2008 at 5:38 pm
    I’m attempting to capture some on-screen clips of our engineers working with their CAD software to be used in a DVD. I’ve settled on using CamStudio for the capturing. Among the few codecs it offers is “Microsoft video 1,” which is the only one that doesn’t result in a choppy video.
    We’ve captured several video clips in this fashion and it appears fine if played with a stand-alone player. When I bring them into Premiere (CS3), however, the video appears extremely choppy and generally mangled. This is the case before & after rendering/encoding.
    The only solution I’ve come up with is to use VirtualDub to basically remove any/all compression before bringing it into Premiere. While this works, it results in VERY large files that aren’t very manageable. Any thoughts?
    Joel Thiessen replied 17 years, 11 months ago 3 Members · 4 Replies
  • Mike Velte
    October 15, 2008 at 7:11 pm
    Does not Cam Studio offer export as Techsmith Screen capture codec or Full frames uncompressed?
    Camtasia does and Premiere can edit the Techsmith stuff.
  • Dan Lind
    October 16, 2008 at 7:59 pm
    I have the same problem in After Effects (CS3). I posted a question about this some days ago, but I can’t find my post, so I guess I made a mistake or two.
    Anyway, this is what my result looks like:
    https://www.hoodwings.com/testarea/ae_twitch.mov
    Is it the same problem for you Joel?
    Switching codecs, or even file format, doesn’t seem to work. But I’ve used Camstudio for years and it’s always worked before, first I thought I screwed up the settings, but same thing on different computers, even after clean install.
    Any thoughts appreciated!
  • Joel Thiessen
    October 17, 2008 at 3:24 pm
    I was getting a similiar distortion on Premiere. Although for me it was more of a “skipping” then a “shaking.”
    At any rate, I finally resolved the issue by using CamStudio and the Lagarith lossless video codec to capture my footage. You can find it here: https://lags.leetcode.net/codec.html.
    Good luck!
  • Joel Thiessen
    October 17, 2008 at 3:56 pm
    Forgot to mention… If you do use that codec you’ll likely want to check the “enable null frames” option in the configuration for screen captures.
