Activity Forums Blackmagic Design Premiere Trimmer Window Problem
  • Premiere Trimmer Window Problem
    Posted by Ryan_j on June 4, 2007 at 12:35 am
    Hello fellow herd members,
    I have a small problem with premiers trimmer window when previewing
    files using the Blackmagic Multibridge Pro. I can only play the first couple of frames and the vision freezes but the audio contniues which make it hard trying to look through long clips.
    It would be great if someone might have a fix.
    Cheers
    Ryan.
    Ryan_j replied 19 years, 3 months ago 2 Members · 2 Replies
  • Martin Kraut
    June 4, 2007 at 10:31 am
    Which driver version you are using ?I remember that this was a bug until version 6.0 but only when you are using the bmd dv preset inside premiere 2.0
  • Ryan_j
    June 5, 2007 at 4:26 am
    I’m using version 6.1.2
