Activity › Forums › Apple Final Cut Pro Legacy › Premiere to Final Cut. Worth it?
Posted by Aj Reuter on February 4, 2011 at 3:59 amI am a junior in highschool, and am in my TV2 college class.
This semester, we are focusing on private projects. I use premiere, but i cant seem to get good DVD burning, and quality i want with it. I have a sony Hf-20, that records to AVCHD 1080p
Im curious if its worth the extra grand to buy an Imac that will run final cut for small projects decently.
I plan on using these in my portfolio for colleges. I know final cut for the most part already, i used it for my video production back in 6th, 7th, and 8th grade (ive been interested in video production for a while)
sorry for all the typos, written on my phone 🙁
Frank Black replied 15 years, 7 months ago 6 Members · 14 Replies -
Dave Davin
February 4, 2011 at 9:28 amHi Aj
I’m an FCP user for a long time now and I’m hooked on the system, but of course like all programs they have their positives & negitives in comparison with others…
Check this video that puts FCP up against Premiere
it might help you out
Dave
Dave Davin
Creative DirectorRAIC Productions
http://www.raicproductions.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Dennis Radeke
February 4, 2011 at 10:58 amI would say that your issue isn’t with an editor per se but with getting a good final output. I’ve always felt that encoding was still more of an art than science and I deal with questions on encoding all of the time. I would do research on why you’re not getting the final output you want and then worry about which editor you want to use. A starting point is to look through Adobe Media Encoder and the many presets that are available. Creative Cow also has a DVD on encoding that is available and good.
In the end, FCP is a capable editor. So is Premiere Pro. Use what feels best.
Dennis – Adobe guy (literally)
Tom Wolsky
February 4, 2011 at 2:25 pmDreadful shoot out. Couldn’t believe the FCP editor was doing everything with drag and drop. He’s used the color corrector filter, not 3-way, which is realtime. He’s clearly uncomfortable with the computer, which has been set up with Expose hot spots. He’s dragging clumps of timeline to make room for clips. Dragging whole clips into the timeline and dragging to cut them up. Doesn’t know how to do a ripple delete. If one guy gets to send to AE the FCP editor should have been allowed to send to Motion for the cartoon effect. It looked like he did the PIP in the viewer rather than with image+wireframe right in the canvas. It looked like he added transitions individually rather than selecting a section and pressing a shortcut. A Premiere evangelist against a run of the mill editor. Maybe Soule against Nick Meyers would have been interesting. This was a pretty bad display and nothing like what you would see from an experienced FCP editor. He did pretty well considering his technique. The rendering at the end is really what killed it.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Herb Sevush
February 4, 2011 at 4:55 pmAj –
You won’t get better DVDs just by going to final cut, or Apple for that matter. There are differences in the 2 systems, and I prefer Final Cut, but not because of better output.
Herb Sevush
Zebra Productions -
Aj Reuter
February 4, 2011 at 9:32 pmthe problem is, i will.
Because fcp has the burn to disk right on it. I ONLY have premiere and after effects. no encore or anything…
that and i love FCP.
Frank Black
February 14, 2011 at 1:13 amHi Dave —
what do you mean by “The rendering at the end is really what killed it.?
i tried to look toward the end but am not finding what you mean. can you please explain, this is so important for me. Thanks
Tom Wolsky
February 14, 2011 at 2:18 amIf you watched the video toward the end the FCP editor had to spend a great deal of time rendering for output.
All the best,
Tom
Frank Black
February 21, 2011 at 6:43 pmTom, sorry about the delay and thanks for your response. Not sure why I called you Dave, very sorry about that.
Thanks again. It seems that every forum I check, rendering is the issue discussed when it comes to fcp. I still want nothing but fcp but sometimes imagine myself being totally surprised by the rendering.
Any additional thoughts on this? Do you use fcp as your main editor and does the rendering really bother you.
Tom Wolsky
February 21, 2011 at 6:51 pmRendering doesn’t bother me much because it’s the end part of the process. I almost always work in Unlimited RT and never render while I go, but only at the end and I don’t have to watch the computer do it.
All the best,
Tom
Frank Black
February 21, 2011 at 7:52 pmTom, what you just said kinda eliminates the worry about rendering entirely. Can it really be done this way? From my research, I gathered that rendering has to be done with every small addition you make if you wanna see right away how the addition came out — like adding a title, for example.
I’ve been researching FCP vs Vegas for a long while now, and a lot has been said in favor of FCP, but it seems to me that the differences being mentioned are ones that I’ll never even notice, and this leaves the rendering issue the only one to be concerned with. Any thoughts? I’d appreciate any and all direction you can give me at your convenience. Thanks.
