Activity Forums Apple Final Cut Pro Legacy premiere to final cut pro
  • premiere to final cut pro
    Posted by Felix Koziol on October 16, 2007 at 1:40 pm
    Hey everybody – today I get a Harddrive with data from AdobePremiere on PC – a EDL with .avi DV clips. No Problem importing the EDL, but I can’t playback the avi-files. As I open them in QT Player its format is named “dvsd”. I work with FinalCut6 on Mac OS 10.4.9 and QT 7.2
    best regards,
    Felix
    Felix Koziol replied 18 years, 11 months ago 3 Members · 5 Replies
  • Soreyrith Um
    October 16, 2007 at 4:44 pm
    Are you able to import the avi files into a new FCP project? I’ve never had problems bringing .avi files into FCP.
    http://www.HotSpotsOnline.com
  • David Bogie
    October 16, 2007 at 5:58 pm
    The drive format usually only affects writing to the drive but try copying one of the files to your Mac and then try to import it.
    bogiesan
  • Felix Koziol
    October 17, 2007 at 1:29 pm
    hey – so maybe I forgot to say – I copied the files before opening the EDL. And the Problem is not importing the clips into FinalCutPro – but to playback the files. Also in QuickTime Player. They were captured in Premiere as DV – QuickTime Player says format is “dvds”
    felix
  • David Bogie
    October 17, 2007 at 1:55 pm
    Yeah, there’s probably plenty you haven’t bothered to say.
    What do you mean, in no uncertain terms, by won’t “play?”
    bogiesan
  • Felix Koziol
    October 18, 2007 at 8:48 am
    hey – I mean if I try to playback QTPlayer as well as FCP just show a white screen – but I can remember playback avi from Adobe Premiere on a Mac System before. I can hear sound but I can’t see any picture. So my workaround was to convert them with streamclip. But there must be a way without converting….So maybe somone knows this problem and maybe a solution…
    regards
