Activity Forums Adobe Audition Premiere to Audition Render and Replace doesn’t work
  • Premiere to Audition Render and Replace doesn’t work
    Posted by Elliott Wright on July 22, 2010 at 5:22 pm
    OK, so whenever I try to edit a sound file off of the timeline in Premiere Pro by rendering and replacing in Audition it doesn’t work.
    First thing is that the render and replace box says not responding for a few minutes. The system’s memory usage climbs and climbs then drops during this time over and over. Finally Audition will come up and you can see the file listed in the multitrack window. But it can’t be edited because it generates nothing under the edit window. Weird thing is it’ll still try to build a spectral display (nothing comes up). I have no idea why.
    I’m completely lost as of now. Any help would be much appreciated.
    Elliott Wright replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
