Activity Forums Adobe Premiere Pro Premiere settings. Set up and export
  • Premiere settings. Set up and export
    Posted by Tessa Garland on September 5, 2016 at 12:14 pm
    Hi
    I am making a short film to send away to film festivals with a friend. I am used to editing and working with HD video files shot at 25fps but these files are animations (CGI) created in Cinema 4D. The files are Quick Tiime 1080 x 1920 and have a frame rate of 30fps. I am using Premiere CC to edit.
    I have two questions;
    What sequence settings should I use and secondly what are the best output settings? I often send my work to film festivals with a frame rate of 25fps (I’m from the UK). Would this work the frame rate is 30fps -would this create a problem, particularly because I often get selected to be on showreels with other film makers, where frame rates will be different.
    Apologies this is a basic question but my first animated work.
    Tessa Garland replied 9 years, 11 months ago 1 Member · 1 Reply
  • Tessa Garland
    September 6, 2016 at 3:25 pm
    OK thanks for your reply.
