Activity › Forums › Adobe Premiere Pro › Premiere sequence to Final Cut Pro XML not translating over effects.
  • Premiere sequence to Final Cut Pro XML not translating over effects.
    Posted by Denrei San on July 17, 2013 at 1:12 pm
    Footage was shot with Nikon D7000 in 1080p H.264.
    Transcoded to ProRes 422.
    Edited ProRes footage in FCP7.
    Exported as XML file.
    Imported into Adobe Premiere Pro CS6.
    Applied Warp Stabilizer effect to all footage.
    (If this matters, fyi: footage has yet to be rendered for preview.)
    Exported as Final Cut Pro XML file.
    Received this error message in the results report:
    Translation issue:
    Sequence at 01:00:00:00, video track 1: Effect on Clip not translated.
    Help?!
    Denrei San replied 13 years, 1 month ago 3 Members · 4 Replies
  • Tero Ahlfors
    July 17, 2013 at 5:42 pm
    What software are you using to open the XML file made by Premiere?
  • Angelo Lorenzo
    July 17, 2013 at 7:24 pm
    XML files are simply text instructions for an NLE program to create bins/timelines and so on. Warp Stabalizer is an Adobe-specific effect and, as such, has no matching feature that can be represented by an XML file so the resulting effect is stripped.
    Best thing to do is to render out that clip with the effect and once the edit is in FCP 7 (as your post would suggest thats what you’re trying to do) you can use a replace edit.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Denrei San
    August 8, 2013 at 11:55 pm
    Final Cut Pro 7.
  • Denrei San
    August 8, 2013 at 11:57 pm
    I see. I’d hoped there was a non-render solution as the footage is an hour long… Well, thanks for the help. I’ll go ahead and do that.
