Activity Forums Adobe Premiere Pro Premiere says media is offline but they are not
  • Premiere says media is offline but they are not
    Posted by Philippe Gosselin on April 7, 2016 at 4:13 pm
    Hi all,
    I am trying to render my project and two shots, that are from files who are online, are rendered with the red offline warning.
    I tried to reveal both in the project panel and the explorer and indeed they are there and in the project panel it doesn’t say “media offline” in the the Media Type column…and, of course, when I hit Play, both shots plays fine. This only happens when I render the sequence and it happens whether I render in Premiere or Media Encoder.
    I’ve tried emptying the preview folder to no avail
    Any advice?
    Jon Doughtie replied 10 years, 5 months ago 3 Members · 4 Replies
  • Pierpaolo Ferlaino
    April 7, 2016 at 4:51 pm
    Try to delete your media cache and see if it solves the problem.
  • Philippe Gosselin
    April 7, 2016 at 5:11 pm
    Nope, that didn’t do anything.
    I tried save the project under a new name = nothing
    I copied the supposedly missing files in another folder and replace the footage with the copies and that seems to have done it.
    April 7, 2016 at 5:49 pm
    Glad to hear you solved the problem…
  • Jon Doughtie
    April 7, 2016 at 6:07 pm
    I have run into this once in a while too. I rename the folder, then replace the media, and it is good to go.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
