Activity › Forums › Adobe Premiere Pro › Premiere Proxy vs Transcode?
  • Premiere Proxy vs Transcode?
    Posted by Nick Mars on October 6, 2020 at 1:28 am
    Hi all,
    Longtime Avid editor here who was real accustomed to the proxy workflow. Been using Premiere (new jobs, new skills right?) the last few years and now using it for a home project where I’m actually handling media creation.
    I have some gnarly 1080p 240fps H.265 (HVEC) GoPro files. Just for fun I brought a few into Premiere, and as expected even my iMac Pro just went “nope” trying to playback even at 1/8th.
    So I can obviously create proxies, but since this is destined for the web and and all 1080p, I would rather do some batch encoding up front so figured transcodes would be a good option. But no matter what I try (DNxHD, ProRes 422, GoPro Cineform etc) it cuts the footage frame rate from 240fps to 60fps. I did some googling and found that Media Encoder can no longer go above 60fps….
    (sidenote: Really, Adobe? I get export not needing more than 60fps, but on ingest? Also don’t call it “Match Source” then)
    So now I’m curious: Do I actually have a transcode option with Adobe to maintain the 240fps (I would like to speedramp it while editing), or am I forced to go with proxies and a re-link?
    If I can transcode, what am I missing here?
    Thanks in advance!
    – Nick
    Nick Mars replied 5 years, 11 months ago 1 Member · 1 Reply
  • Nick Mars
    October 6, 2020 at 6:49 pm
    If anyone is wondering the same thing, I finally found the best workaround to be interpreting the H.265s down to 24fps (or whatever desired frame rate is) and then making proxies of those interpreted files. Only way I see to transcode workflow would still be bringing the H.265s into Premiere, interpreting, and then just exporting as whatever final format you want.
