Activity Forums Adobe Premiere Pro Premiere Project doesn’t load
  • Premiere Project doesn’t load
    Posted by Sara Carrilho on December 9, 2010 at 5:12 pm
    Hello! I’ve seen several posts about this subject but I still can’t solve my problem… The thing is, the load bar get’s stuck and I can’t access the project. I’ve finished it, so it’s very annoying because I cannot render it.
    Here’s what I can say… I tried moving the files from location (couldn’t open it, anyway) and opening an auto-saved version of the project (I can do it but I lose a lot of information). I don’t have this loading problem since the beginning of the project, so I don’t know what cause it… I had to change the resolution of almost all the videos, so I used After Effects to do it (it’s not the best method, I know, but it’s what I’ve done). Besides that, I made a small animation in AE too. All that is in the project as well as a bunch of mp3 files.
    Thanks in advance.
    Sara Carrilho replied 15 years, 7 months ago 3 Members · 5 Replies
  • Jeff Pulera
    December 9, 2010 at 9:13 pm
    Hi Sara,
    What often works is to create a NEW project with the same Sequence Preset, then Import the old project. It will come in as a folder, you need to then open that and open the sequence
    Jeff Pulera
    Safe Harbor Computers
  • Sara Carrilho
    December 9, 2010 at 11:40 pm
    First of all, thanks for your sugestion.
    Anyway, I tried to do that but, when I ask to import the entire project, the window doesn’t load too. And when I ask to import only the selected sequences, an error appears: “An Adobe Dynamic Link error occurred” and then a strage window pop’s up…
  • Sara Carrilho
    December 12, 2010 at 1:25 am
    So, I solved the problem… Since the auto-saved files were “too old” and I’d done a lot of changes after that, I went to temporary files on my computer and opened a newer version. Once I did that, I realized I wasn’t able to save the project, exiting Premiere and open it again. I was thinking about finishing it without exiting Pre but tried to render some minutes to make sure it worked. It didn’t, and the error that Media Enconder detected was something related to the main sequence, it didn’t found it’s the origin. And then, I created a new sequence, copied the data to it and deleted the old one. Why? I still don’t have a clue. I hope this can be useful to somenone.
  • Steven Pritchard
    December 12, 2010 at 4:58 am
    Sarah, I have the same problem and all the many and varied solutions that I read do not solve the problem. You mention opening temporary files, can you explain as I don’t find those on my pc?
    Many thanks
    Steve
  • Sara Carrilho
    January 28, 2011 at 11:22 am
    Sorry for the delay but I din’t received an alert on my mail regarding this message. In case you still need the info, I think I opened a “run” window and typed “temp” or “temporary files”. I don’t have access to my pc now but you can easily find the answer on google. 🙂
