Activity Forums Blackmagic Design premiere pro/intensity pro/no audio
  • premiere pro/intensity pro/no audio
    Posted by Mike Roberts on March 5, 2012 at 10:50 pm
    hey guys, can’t seem to get the audio to play in premiere pro. The card works flawlessly with After Effects, and premiere seems like it’s working, but i can’t get audio even thought the meters are dancing, even with the Blackmagic presets.
    Any help would be appreciated.
    Mike
    Mike Roberts replied 14 years, 6 months ago 2 Members · 4 Replies
  • Justin Strauber
    March 6, 2012 at 4:20 am
    Do you have your speakers connected to the BMD board or just the computer? With the BMD board installed, playback audio will default to the board rather than your PC sound card.
    If your speakers aren’t hooked to the BMD, you can remap premieres output to use your PC speakers in the preferences.
  • Mike Roberts
    March 6, 2012 at 4:50 am
    Thanks Justin. I’m on a Mac and have tried all the other setting
    In premiere. Speakers etc… Also it all works great in AE!
  • Justin Strauber
    March 6, 2012 at 4:55 am
    These are the instructions from the Adobe site for CS5 / CS5.5, have you checked this setting?
    – Premiere Pro > Preferences > Audio Output Mapping (Mac OS).
    – In the Preferences dialog box, from the Map Output For menu, choose the driver for the device desired. By default, Premiere Pro selects Built-In (Mac OS).
    You want to make sure that’s set on Built-In. If it is, then you got me puzzled. I don’t have a Mac with BMD hardware in it, so I can’t see if I can reproduce it, but on my PC, all my audio in Premiere goes through my Decklink SDI card, regardless of timeline preset. I can change it via the windows version of the settings above.
  • Mike Roberts
    March 6, 2012 at 6:01 am
    Thanks Justin,
    |t’s a real puzzle. sound works great on all other settings but the blackmagic ones, no matter what i select… very weird.
