Activity Forums Blackmagic Design Premiere Pro2.0 Slowness…It’s that Right?
  • Premiere Pro2.0 Slowness…It’s that Right?
    Posted by Bernardo on March 22, 2006 at 6:07 pm
    Hi guys.
    Just to check if someone it’s having the same problem…
    I did install the Premiere Pro 2.0 last night.
    I did a test with the same color correction effect on both versions 1.5.1 and the new 2.0.
    Well, the render time on the new version (2.0) it’s 3X slower than the previous one..
    1- PPro v 1.5.1 render time = 2 minutes (1″ clip)
    2- PPro v 2.0 render time = 6 minutes (1″ clip)(not using maximum bit depth render)
    This’s normal?
    I’m running DL Extreme PCIe with Premiere Pro on a certified Blackmagic System:
    INTEL PENTIUM DUAL CORE
    Asus P5WD2 Premium
    Intel Pentium D Dual Core 830
    3 SATA disks with 8MB cache using onboard RAID
    nVidia GeForce NX6600
    4GB DDR2 800 RAM (CORSAIR TWIN2X2048-6400PRO)
    535 watt Power supply (24 pin) – Enermax
    Thanks in advance.
    Bernardo
    Rio de Janeiro – Brasil
    Bernardo replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
