Activity › Forums › Adobe Premiere Pro › Premiere Pro with large Video in Timeline crashing !!
  • Premiere Pro with large Video in Timeline crashing !!
    Posted by Wolf on April 6, 2005 at 9:35 pm
    I have a big problem with films with many cuts and effects in the timeline. (duration about 10 minutes only)
    If I change now blocks in the timeline, the Program hangs itself up and the raid-disk (not the system-disk with
    the operation system) work very strongly.
    If I have patience and wait, the Program returns after a few minutes.
    With a film, which is not so complicated, but is even much longer (30-40 minutes) and I change blocks, everthing is okay.
    I think my computer is fast enough: P4 3,2 Gh, 4GByte RAM!! Disk Raid with 800 Gbyte (4 S-ata disks) and decklink pro
    To find the problem i exchanged the raid-disks (4 new disks!!) as the systemdisk,
    installed again the operating system, changed the Raid-controller!!, changed the Ram-memory!!!!
    I tried already everything, nothing helps.
    Also i installed a Program those from time to time the RAM delete…. no chance.
    Perhaps someone found the same problem and a solution.
    I hope for your assistance…..please help
    Claus-Peter Wolf
    Rob De jong replied 17 years, 4 months ago 5 Members · 10 Replies
  • 10 Replies
  • Aanarav Sareen
    April 7, 2005 at 1:55 am
    [Claus-Peter Wolf] “If I change now blocks in the timeline”
    What do you mean by blocks?
  • Wolf
    April 7, 2005 at 9:23 am
    in the timeline are the clips i edited and when i take some or all clips
    and push them some frame to the right side to place a new clip.
    then not alway but in the mosted cases premiere crashing!!!
    any idea??
    thanks
    Claus-Peter Wolf
  • Mike Velte
    April 7, 2005 at 11:32 am
    My understanding is that Windows XP supports only 2 GB of RAM. I would try the same project with just 2 GB RAM and maybe with just one. Also make sure your page file is not on the system drive.
  • Wolf
    April 7, 2005 at 3:26 pm
    Hi
    I tried with 2 and 1 Gbyte Ram, same problem.
    How to i have to change the pagefile, to be not on the systemdisk?
    thanks
    Claus-Peter Wolf
  • Mike Velte
    April 7, 2005 at 8:45 pm
    Right click on My Computer and choose Properties>Advanced>Performance options>settings>Advanced>Virtual memory>Change…Select the Drive for the Page File…custom size for 2 GB is Initial size= 1536, Max size is 3072.
  • Wolf
    April 8, 2005 at 7:30 am
    Thank you….i changed it…but unfortunately it did not help 🙁
    Mhhhhh….someone has still another idea ????
    Claus-Peter Wolf
  • Bill Buchanan
    April 8, 2005 at 2:26 pm
    Claus:
    I (and I believe Peter Corbett, too) wrestled with PPro crashing. I was near the end of cutting a 20 minute film when the crashing began. It actually began after I installed a BMD driver update. Everytime I adjusted the length, moved or brought a new clip to the timeline, I would get the “a serious error has occured…” message. I finally uninstalled that driver update and reinstalled the previous driver. The crashing ceased. I forget which driver versions they were, but they were several versions back.
    After the project was finished and output (but still in my system), I reinstalled the driver I thought was to blame for the crashing. I did everything I could think of to recreate the crashing, but it did not occur even once. Go figure.
    So, if you haven’t tried completely uninstalling the BMD driver and software, you might want to give it a try. As you well know, great mysteries lie within these very un-finite machines whereby mere restarting solves most problems. Good luck.
    Bill Buchanan
  • Wolf
    April 8, 2005 at 3:14 pm
    Thank you Bill,
    i will try do install a previous driver version and look if premiere still crashing.
    (i already installed windows XP, Premiere Pro and decklink on a brand new disk, but it still crashed)
    But perhaps, when i install a new driver, deinstall it, install a old dirver..deinstall the old driver and then reinstall again the new driver… 🙂 who knows….perhaps it will work.
    You a right with mysteries in maschines 😉
    Thanks….i tell you the result
    Claus-Peter Wolf
  • Wolf
    April 8, 2005 at 8:53 pm
    Hi Bill
    You do not believe it.
    I installed the old driver (4.7) and Premiere functioned now great. Unbelievably!
    I don
  • Rob De jong
    May 9, 2009 at 9:01 am
    BMD is Black Magic ……. I do not have that on my PC, but I have the same problem of crashing and serious errors. Would there be a suggestion for a BMD-less PC (quad core)?
