Activity › Forums › Blackmagic Design › Premiere Pro with large Video in Timeline crashing !!
  • Premiere Pro with large Video in Timeline crashing !!
    Posted by Wolf on April 6, 2005 at 9:33 pm
    I have a big problem with films with many cuts and effects in the timeline. (duration about 10 minutes only)
    If I change now blocks in the timeline, the Program hangs itself up and the raid-disk (not the system-disk with
    the operation system) work very strongly.
    If I have patience and wait, the Program returns also little luck after a few minutes.
    With a film, which is not so complicated, but is even much longer (30-40 minutes) and I change blocks, everthing is okay.
    I think my computer is fast enough: P4 3,2 Gh, 4GByte RAM!! Disk Raid with 800 Gbyte (4 S-ata disks) and decklink pro
    To find the problem i exchanged the raid-disks (4 new disks!!) as the systemdisk,
    installed again the operating system, changed the Raid-controller!!, changed the Ram-memory!!!!
    I tried already everything, nothing helps.
    Also i installed a Program those from time to time the RAM delete…. no chance.
    Perhaps someone found the same problem and a solution.
    I hope for your assistance…..please help
    Claus-Peter Wolf
    Wolf replied 21 years, 5 months ago 3 Members · 12 Replies
  • 12 Replies
  • Dalen Quaice
    April 6, 2005 at 10:16 pm
    What model motherboard are you using?
  • Peter Corbett
    Yes, I also am cursed with this problem. I just monitor the RAM usage and close down and reboot before continuing on. It very frustrating, but I understand the problem is being worked on by Adobe. If you are using lots of PSD images in your project, this will suck system resources. Change them to TIFF, Targa or JPG’s.
    Peter Corbett
    Powerhouse Productions
    Australia
  • Peter Corbett
    April 6, 2005 at 10:17 pm
    I seriously doubt it’s anything to do with the motherboard, just the issues I mentioned above.
    Peter Corbett
    Australia
  • Wolf
    April 7, 2005 at 9:14 am
    It
  • Wolf
    April 7, 2005 at 9:17 am
    Hi Peter,
    the is only video footage in my timeline no psd, tiff or big jpg!
    and freeRam don
  • Peter Corbett
    April 7, 2005 at 9:45 am
    Are the clips large in size? Moving large files around in Premiere just suck RAM like a lemonade in the Sahara.
  • Wolf
    April 7, 2005 at 10:54 am
    the clip is about 10 minutes and with 250 cuts with many effect (all effect are rendered)
    …uncompressed avi…i
  • Peter Corbett
    April 7, 2005 at 11:05 am
    Claus,
    I just think this is a flaw with the current version of PPro. I can’t think of anything you can try except if you are “close” to finishing, export the sequence to BM codec or uncompressed AVI, create a new project, import the new export and import ONLY those elements you need to complete the project. It’s not the most flexible way to do it, but it won’t use up all the system resources like you are doing now.
    Peter
  • Wolf
    April 7, 2005 at 11:55 am
    Thank you Peter for your help,
    perhaps: do you think it could be my chipset
    i have a 865pe and decklink
  • Peter Corbett
    April 7, 2005 at 12:05 pm
    I don’t kmow Claus. I doubt it somehow. You project sounds typical of the problems I’ve had with complex projects with lots of edits. Are you close to finishing? If so I would recommend doing that export idea use a new project. Not an ideal solution. At least try it as a test to see if things improve.
    Peter
