Activity › Forums › Adobe Premiere Pro › Premiere Pro w/ Decklink HD Pro card on AMD 64 system…is it possible?
  • Premiere Pro w/ Decklink HD Pro card on AMD 64 system…is it possible?
    Posted by Knick Tran on April 27, 2005 at 4:04 am
    In the process of building new system, to above spec, but not sure if there will be compatiblity issues. Anyone had success or failure to above spec or similiar. Thanks.
    Brian Deviteri replied 21 years, 5 months ago 2 Members · 1 Reply
  • Brian Deviteri
    April 27, 2005 at 1:11 pm
    This is being discussed on the Adobe forum as well…
    Someone on there is running an AMD 64-bit processor at 32-bits and it works fine. Right now, I doubt that PPro supports 64-bit processors in 64-bit mode. I’ve heard that even Windows XP Professional cannot handle 64-bit and that there is a copy you can get “somewhere” that probably isn’t 100% legal that can do 64-bit, but even then, unless the software application can do 64-bit, it will not work. I’ve also read reports of even MS Word not functioning on a 64-bit running system, so this is a major issue. I would wait until the end of this year or sometime next year when the “Longhorn” beta versions are released and tested before going with a 64-bit and running it in full 64-bit mode.
