Activity Forums Adobe Premiere Pro Premiere Pro v7.0 video crop problem
  • Premiere Pro v7.0 video crop problem
    Posted by Jessyager on December 2, 2006 at 11:28 pm
    I am still fairly new to editing with premiere pro I do graphic design and in that field adobe is the standard so when I started dabbling with video I figured they could not be too far off so I purchased this to mess with… I mainly use this to compile game video’s.. I have been using it quite a bit with flight simulator with no problems because there is not much around the outside border of much significance but now I have started using it for counter-strike vidoes and I have noticed when I export it cuts a significant part of the outside border off of the video as well as quality going down a bit in the end result… I am using FRAPS to capture and exporting back to standard avi what can I do to fix these problems??? any help would be greatly appreciated. Thanks, Jess
    Alex Jusay replied 19 years, 9 months ago 2 Members · 1 Reply
  • Alex Jusay
    December 3, 2006 at 4:37 am
    I noticed that you don’t like to use punctuation–which can really help us understand your problem. Anyways, scale your source video to match your project settings: 720×480 for NTSC, 720×576 for PAL. What export setting do you use? AVI? Mpeg?
