Activity › Forums › Adobe Premiere Pro › Premiere Pro Trial AJA LHi
  • Premiere Pro Trial AJA LHi
    Posted by Ed Quinto on June 23, 2011 at 11:26 pm
    Trail Version of PP 5.5
    Cant figure out how to enable monitoring thru the AJA LHi card. downloaded and installed latest AJA drivers and MAC CS5 plugins. is it disabled in the trial version?
    Kevin Monahan replied 15 years, 3 months ago 4 Members · 6 Replies
  • Alex Gerulaitis
    June 24, 2011 at 12:21 am
    Should still work in trial mode. Are you using AJA sequence presets?
    Alex (DV411)
  • Chris Knight
    June 24, 2011 at 12:37 am
    Not sure how it works in OSX, but in Windows, you won’t see any output via SDI, unless you pick an AJA sequence preset (and then double-check everything in the playback settings, under project menu). If you’re monitoring analog, it defaults to composite only, until you go into the playback settings to change it to component.
  • Ed Quinto
    June 24, 2011 at 2:12 am
    This is in OSX 10.6
    The AJA sequence presets dont show up in the project settings. I can only select HDV and DV… AJA shows up in my paid Photoshop 5 exports.
  • Kevin Monahan
    June 24, 2011 at 3:52 pm
    If you are having trouble with AJA issues, I recommend contacting AJA tech support. Report your findings back here and let us know what they said. Others can benefit, I am sure!
    AJA Tech Support: https://www.aja.com/support/contact-support.php
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Ed Quinto
    June 24, 2011 at 6:41 pm
    AJA support: plugins for the LHi card and PP 5.5 are on the way, soon.
    “Hi Ed,
    The plugins for CS5.5 have not been released yet.
    However they should be released Very soon now……any time.
    Check our web site periodically for the released plugins.
    Best regards,
    Keith”
  • Kevin Monahan
    June 24, 2011 at 8:52 pm
    Thanks for the update, Ed.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
