Activity Forums Adobe Premiere Pro Premiere Pro to .vob DVD files ?
  • Premiere Pro to .vob DVD files ?
    Posted by Soumendra Jena on March 15, 2013 at 7:00 am
    Hi, we deliver our clients in DVDs, which they play at home on their DVD players .
    On Premiere Pro, when I select MPEG DVD, it exports the file to m2v file.
    I wrote that to a DVD , and the DVD player did not recognize the file.
    I guess, the only way is the AUDIO_TS , VIDEO_TS folders, .vob files structure.
    So, how do we export from premiere pro using media encoder to get this file structure ?
    So, we can simply write those to a DVD disc and we are done.
    Jeff Pulera replied 13 years, 6 months ago 5 Members · 5 Replies
  • Angelo Lorenzo
    March 15, 2013 at 7:40 am
    These exported files need to be used in conjunction with a proper DVD authoring program like Adobe Encore. Placing these files on the disc as a data disc will not work as you’ve experienced first hand.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Soumendra Jena
    March 15, 2013 at 8:58 am
    Ok so export in a h264 should be okay or MPEG DVD and then take it ro Adobe Encore and author it and export ?
  • Satyen Guru
    March 15, 2013 at 9:30 am
    If you are using CS4 or higher, you can use dynamic link.
    Check out Using Dynamic Link with Encore.
  • Gabriel Sanchez
    March 15, 2013 at 11:00 am
    Send your PPro sequence to Encore DVD through Dynamic Link and it´ll make the dvd structure, burning the video in a Video_TS and Audio_TS folders.
    Other way is exporting the sequence with Adobe Media Encoder with the Mpeg2 DVD preset, set the quality to max. and bitrate to 7 mbps max.
    If you choose DVD multiplex it will generate an .mpg file with audio and video included in one file, if you don´t choose DVD multiplex then you´ll have an audio file (mpg or PCM depending on the audio settings) and a video file (m2v) separated, which you´ll need to join in Encore or any other authoring program. Both ways will work fine, but in both of them you´ll always need to load the files in a DVD authoring program in order to burn a DVD with the standard Video_TS and Audio_TS folders.
    Regards
  • Jeff Pulera
    March 18, 2013 at 2:27 pm
    Hi Soumendra,
    I’m not a fan of Dynamic Link, so your first try was correct in exporting the “MPEG-2 DVD” files. As mentioned though, you must bring the exported video and audio file into Encore using “Import as Timeline”, and then burn to DVD from there, so that the correct file structure and format is created for DVD playback.
    I would like to add that exporting a single .mpg file (multiplexed audio) from Media Encoder is NOT a correct workflow for Encore. By default, the “MPEG-2 DVD” preset in AME will create .m2v and .wav files. This is what you want. Encore will convert the uncompressed .wav audio directly into high-quality Dolby AC-3 audio for you automatically.
    If you set “Multiplexing” in AME to “DVD”, it will combine the audio and video into a single file. The problem is that the audio is compressed as MPEG audio, which is a lower quality than Dolby. Then, Encore must de-mux (separate) the audio and video, and then re-encode the already compressed audio into Dolby. This means extra encoding time and definite quality loss. Stick with the .wav audio, or if you have CS6, you can export direct to Dolby AC-3.
    So, in Export settings for MPEG-2 DVD, set “Multiplexing” to NONE. Under AUDIO tab, select PCM to create the .wav file, or with CS6, you can choose “Dolby”. Use the default “Dolby Digital” and NOT the “SurCode” option, which is a surround encoder that you must purchase. Older versions of Encore all have the SurCode trial, but NOT the stereo Dolby encoder, so just use PCM in that case.
    Thank you
    Jeff Pulera
    Safe Harbor Computers
