Activity › Forums › Adobe Premiere Pro › Premiere Pro shutting down importing DV clip
  • Premiere Pro shutting down importing DV clip
    Posted by Nasa Tim on October 28, 2005 at 8:08 pm
    I’m running Premiere Pro 1.5 on three different systems. Tried capturing DV footage played out of a Sony HDV deck (in DV mode of course) and captured via 1394 cable into Premiere. Premiere asks me to save clip, click OK, program shuts down. Open program, try to import clip just captured (which plays fine in WMP), click OK, program shuts down. I’ve tried the standard Adobe standard DV preset as well as a Blackmagic DV preset and a Matrox DV preset. Same result everytime. Any clues? Thanks.
    System: Intel Xeon dual 2.0GHz, 2 GB ram, Windows XP Pro.
    Nasa Tim replied 20 years, 11 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    October 28, 2005 at 11:35 pm
    Is this happening on all three systems or just the one system? If it is just one computer, try re-installing the program.
    Aanarav Sareen
    Adobe Certified Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Tim Kolb
    October 29, 2005 at 2:45 pm
    Have you tried capturing the DV clip on the same system from another deck. These Sony decks are new and I’d be curious to see if the deck can be eliminated as a cause first off…
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Nasa Tim
    October 31, 2005 at 8:47 pm
    Found out it was a problem with MetaSan software. I could capture DV footage in two instances: 1. everything captures locally; 2. the capture station was booted up as the MetaData controller. Strange thing though, Premiere only shuts down when capturing DV, not HDV, even though footage is coming out of the same deck. Maybe I should try a different DV deck…
    Thanks for your input.
