Activity › Forums › Adobe Premiere Pro › Premiere pro – sequence to sequence editing avid style
Posted by Christopher Lowden on April 3, 2011 at 8:55 pmHello
I am sure this is not the first time this has been asked, but I can\’t find it anywhere in the manual. Can someone tell me how I can edit from one sequence to another sequence without the record sequence becoming nested – avid style editing. I can do it in fcp so i presume it is possible in premiere.Matt Galuszewski replied 13 years, 2 months ago 6 Members · 7 Replies -
Steve Brame
April 4, 2011 at 1:21 amIf the sequences are in the same project, simply select the clips from the source sequence, then switch to the other sequence and paste. As in Avid, you need to make sure that the destination track on the timeline are selected before pasting. Also, remember that pasting occurs at the CTI’s current location.
Steve Brame
creative illusions Productions -
Christopher Lowden
April 4, 2011 at 6:12 amMany thanks for the very clear response.
I was hoping for something a little more precise, using the in and out points and track specification. My test shows that only highlighting the timeline elements and copy / paste works, which means I have to then cut off the excess media.
I have never understood why nested editing is so good. I would have thought that having the elements unnested would be, in general, much more logical and precise, both for the editor and the machine. -
Alex Udell
April 4, 2011 at 3:07 pmNesting is useful where you want to apply an effect as a global, where applying the effect to each seperate element would not work well.
For example….
you build a multi-layer result in your edit…
then you want to Page turn out of that multi layer effect.
By nesting, the software sees those multi elements as a “single stream” and the page turn can be applied…. applying the page turn to each element with then effect wouldn’t give the same result.
Yet you can still step into the nest to make content changes, which makes it superior to rendering (pre-baking a file)..
does that help?
Alex
Kevin Monahan
April 5, 2011 at 7:16 pmIf you are talking about a “virtual KEM roll” when you are speaking of Avid style, then this feature is not available in Premiere Pro. For sure, make a feature request: https://www.adobe.com/go/wish . More on how to give feedback: https://bit.ly/93d6NF
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Christopher Lowden
April 5, 2011 at 8:24 pmMany thanks for the advice. I have posted a feature request on the adobe site.
Camille Reysset
July 2, 2013 at 1:30 amfinally !!!
https://tv.adobe.com/watch/learn-premiere-pro-cc/edit-sequences-in-the-source-monitor-into-other-sequences/If somebody know how to do that in FCP7, please tell me. I try to find for years.
Matt Galuszewski
July 2, 2013 at 2:58 amYou can edit from sequence to sequence in FCP7 without nesting by (from my memory here) adding the COMMAND key modifier.
For example (again from memory) F9 was insert and F10 was overwrite. If you had a sequence in your source viewer and you pressed F9 to edit in to a new sequence you would get a nest of the source sequence. If you pressed COMMAND + F9 you would get the clips from the source sequence arranged depending on patching assignments.
