Premiere Pro renders blue
Hello all…
I’m having an intermittent problem with Premiere Pro (CS5, operating on MacBook Pr0 17″, i7)…
Occasionally specific clips render as if only the blue channel is coming across. Scrubbing previews on the timeline looks fine. Then when rendered I get the blue phenomenon.
One commonality seems to be that these are clips that have been created and rendered in AE CS5. Quicktime, using the PJPEG codec at around 90%. I’ve tried to rerender and replace them with animation codec, and uncompressed, and have the same issue. On one other occasion the problem seemed to go away by quitting out of Premiere, restarting the machine, and then restarting and re-rendering. But at this point I have a big project waiting to render and the issue is persistant.
The one work around I found that is consistently succesful is to import the Premiere project into AE and render from there, but then all my transitions get obliterated.
Any thoughts ?
Many thanks…
MODE Studios
http://www.modestudios.com
Contributing Editor, Live Design Magazine
Art of the Edit Forum Leader
Live & Stage Event Forum Leader
HD Forum Leader
