Activity Forums Adobe Premiere Pro Premiere Pro reinstall give black output
  • Premiere Pro reinstall give black output
    Posted by Joep88 on April 5, 2006 at 11:46 am
    Hello,
    After a clean install of my computer and premiere pro 2, i get
    black output on my monitor. When i have about 6 video layers premiere doesn’t
    show a red line for rendering, it just leaves the output black. I use a blackmagic card,
    but i don’t think that is the problem. It is premiere that doesn’t see if it needs rendering or not. When i set all layers to off and then again to on, it works.. then i get a picture.
    Strange isn’t ? Any help here ? Bys the way, it is a NTSC project, Pal doesn’t have the problem.
    Joep88 replied 20 years, 5 months ago 2 Members · 2 Replies
  • Ebarfield
    April 5, 2006 at 8:10 pm
    Blackmagic had a problem with 2.0 PP capture, but have heard of no problems like you are experiencing. I doubt they are related. You might want to make sure you have the updated (blackmagic) driver mentioned in Adobe forum related to the capture problem.
    https://www.adobeforums.com/cgi-bin/webx?13@1012.rHM1gmdbhbY.8@.3bbee336/4
    If this link doesn’t get you there, just search for “blackmagic” on adobe PP 2.0 forum.
    later,
    egb
    “deja vu all over again” — Yogi Berra
  • Joep88
    April 6, 2006 at 7:38 am
    The strange thing is that when i use the `delete all render files` option in premiere,
    it won
