Activity › Forums › Adobe Premiere Pro › Premiere Pro: RED with audio imports with wrong timecode
  • Premiere Pro: RED with audio imports with wrong timecode
    Posted by Andy Weimer on July 13, 2020 at 2:21 pm
    Hi all
    I have a problem importing RED footage that has Audio.
    When I import the clips (via Media Browser) on all the clips with audio the MediaStart timecode is off by anything between plus 11 and 27 frames.
    But only on the clips with audio, no matter what frame rate and what resolution. The clips without audio are correct.
    I noticed this when I wanted to import an XML into Davinci Resolve to grade. I got a message telling me the time codes on some clips were not matching with the original. Checking with REDCINE-X Pro the timecodes are all correct in Resolve but the ones with audio are off in Premiere Pro.
    I also tried exporting one of the clips out of REDCINE-X Pro with R3D Trim without the audio. But Premiere would still mess up the Time code by the same amount.
    The clips were shot on Monstro 8K VV in REDcode 10:1 IPP2. All was shot in different frame rates and resolutions. Some of the clips have audio and some don’t.
    Any solutions are very welcome. Thanks.
    Andy
    Andy Weimer replied 6 years, 2 months ago 2 Members · 3 Replies
  • Eric Santiago
    July 14, 2020 at 12:37 pm
    Have you tried creating a simple timeline in REDCINE-X and export an XML?
    To see if there is something going awry with the metadata.
    Have you tried other NLEs?
    Resolve has a free version that will at least let you import R3Ds.
  • Andy Weimer
    July 15, 2020 at 3:50 pm
    Hi Eric
    [Eric Santiago] “Have you tried creating a simple timeline in REDCINE-X and export an XML?
    To see if there is something going awry with the metadata.”
    As I mentioned REDCINE-X reads the timecode properly so there’s not much point exporting an XML from there…
    [Eric Santiago] “Have you tried other NLEs?
    Resolve has a free version that will at least let you import R3Ds.”
    well yes, as mentioned I’ve imported it in REDCINE-X and Resolve and works in both, but I need to do the layout work in in Premiere Pro, and usually Premiere can handle RED without a problem. So I was wondering if someone has experienced this before and might have a hint on what could be the problem.
  • Andy Weimer
    July 15, 2020 at 3:54 pm
    Hi Antoine
    Here’s a link to a small clip with 50fps
    https://we.tl/t-IDXf3RxnXA
    We recorded 8K in 50fps and 4K in120fps
