Activity › Forums › Creative Community Conversations › Premiere Pro reaches a milestone
Posted by Robert D’alexis on August 14, 2014 at 4:46 amand takes NVidia along for the ride. 🙂
https://www.studiodaily.com/2014/08/inside-gone-girls-6k-review-and-editorial-pipeline/Oliver Peters replied 12 years ago 7 Members · 14 Replies -
Robert D’alexis
August 14, 2014 at 1:14 pmYes, you might say that. 🙂
And yet, the next generation of workstations will be even beefier: dual 18 core Xeon, 1 TB of DDR4 RAM, new Quadro cards, etc.
Enough to make one salivate at the prospect of using such a beast of a machine. -
Jeremy Garchow
August 14, 2014 at 4:15 pmThat sure is some beef.
For 2.5k ProRes @ 1080, you could edit on an iMac.
But then it wouldn’t be an nvidia case study.
Shawn Miller
August 14, 2014 at 4:48 pm[Jeremy Garchow] ”
For 2.5k ProRes @ 1080, you could edit on an iMac.”Sure, but there were also the DPX sequences for VFX work… I assume those were 10bit? Maybe that’s what the beefy machines were for.
Shawn
Jeremy Garchow
August 14, 2014 at 5:06 pm[Shawn Miller] “Sure, but there were also the DPX sequences for VFX work… I assume those were 10bit? Maybe that’s what the beefy machines were for.”
But of course.
That, and the 6k 4cam multicam.
I bet editorial was relegated to the 2011 MacPros. 🙂
Jeremy
Michael Phillips
August 14, 2014 at 9:00 pmThe DPX files were probably 16bit at the very last considering the R3D files are 12bits
Michael
Shawn Miller
August 14, 2014 at 9:36 pm[Michael Phillips] “The DPX files were probably 16bit at the very last considering the R3D files are 12bits
Michael”
Yup, completely possible. I would be curious to know what those VFX shots were, and what their pipline/workflow was. Was this a Maya/Nuke/Houdini/AE show with Pr as the hub… or maybe a Modo/Fusion/Ae/Mocha show, again with Pr as the hub. Would really like to see some BTS stuff on this.
Shawn
Oliver Peters
August 15, 2014 at 12:20 am[Jeremy Garchow] “That, and the 6k 4cam multicam.
I bet editorial was relegated to the 2011 MacPros. :)”The NVIDIA case study says that, but I suspect multi-cam editing was only done using the 2.5K Proxy files. Not really that demanding on those machines and those cards. And yes, I’m sure the 2 Macs were used for editing – probably as an editor preference.
If you read any of the past articles about workflows for “Zodiac”, “Benjamin Button”, “Social Network” and “Dragon Tattoo”, the in-house editorial operations have always been very specific to their working style. The last two have been RED jobs, where a lot of the prep work used After Effects prior to the edit. My guess is that all the brawn was applied to pre-editorial and post editorial (conforming) tasks, requiring fast throughput and debayering of RED files, without the use of Red Rocket cards.
– Oliver
Orlando, FL
http://www.oliverpeters.com
