Activity Forums Adobe Premiere Pro premiere pro problem…still images show up as solid green?
  • premiere pro problem…still images show up as solid green?
    Posted by Stan Weiss on September 18, 2005 at 8:21 pm
    Working on a project using a bunch of scanned photos..jpg files…
    all files are about 300 dpi and about 4×6 or so…
    suddenly when i place them in the timeline some of the photos appear normal and others just give me a solid green on the monitor window..
    perhaps someone can me a hint as to what is going on?
    thanks
    Stan
    Stan Weiss replied 21 years ago 2 Members · 2 Replies
  • Aanarav Sareen
    September 18, 2005 at 8:57 pm
    Hi Stan,
    Unfortunately this is a bug in Premiere Pro that only affects a few people. You can find more answers in the Premiere Pro Wiki
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Stan Weiss
    September 18, 2005 at 9:21 pm
    I seem to remember that in Premiere 6.5 there was a problem with stills if you did not have the proper aspect ratio…
    thought this might have something similar here so i played around with the checkbox in the settings that says to bring in clips scaled…not sure what i did but i eventually got things back to normal…I think I re-imported them with the check box off…then even tho i later changed it and went back and put a check mark in the box, things still seem to be OK??? anyways i am back to normal….thanks…Stan
